- Member ID
- #12838
- Messages
- 272
- Reactions
- 967
- Likes
- 117
- City
- Martin
- State
- MI
- Country
- United States
- Vehicle
- 2018 Dodge Challenger Hellcat
After talking with @hellno and seeing some offering transmission rebuilds for $8,0000 dollars we thought it was time to come up with a plan to refresh these transmissions at a more affordable price. The goal was to offer a stronger unit for under $5k
Here is a little run down of the different 3 options
All options will include a tear down, inspection and cleaning
First Option - Factory Refresh. Taking the old worn out clutches and replacing with new clutches. $3495
Second Option - Billet E-Drum with increased capacity factory clutches. This is the same E-drum as the 8hpXtreme just utilizing factory clutches $4495 -- Personal favorite option
Third Option - Billet E-Drum with GPZ Clutches. These are the same clutches and E-Drum as the 8hpXtreme $5495
https://mooredperformance.com/products/8hp90-transmission-refresh
The stock 8HP 90 with factory clutches and a good trans tune can handle really good power. We have decided to offer a refresh service with an option of a Billet Drum and increased clutch capacity. There is also an option to upgrade to GPZ clutches for a more race focused transmission.
This service is for people who are pushing on the car and just want to refresh clutches or add the billet drum and add strength and what the transmission can handle.
STOCK REFRESH ONLY
Disassemble Clean
Includes separator plate needed to strip and clean valve body. Pump bolt and seal kit (PT#68419200AA). Replace pan bolts with steel 10mm head bolts and new filter.
Addons
Disclaimer: This is intended for transmissions that have less then 30k miles on them. If you are in need of a full rebuild please see the 8hpxtreme transmission that is a complete rebuild of the transmission. If there are any questions about this disclaimer contact us before ordering.
STOCK REFRESH ONLY
Disassemble Clean
Addons
- Stock upgraded with billet E-drum and increased clutch capacity OEM frictions
- Refresh with billet E-drum and GPZ upgraded frictions, increased capacity.
- Removal and Install
- 2
- 1
- Show All
