active exhaust valve
Just another way we are all different. I had a Holley Blackheart system on my Daytona. They don't have the valves in it. With the long tube headers and cat deletes it was just to loud for me. I still have the exhaust but if I were to put it on the Hellcats I would modify it and add the valves. I like my cars on the quiet side
Av8ing1
San Marcos
2019 Charger Hellcat
I'd like to have the options of quiet stealth, powerful muscle car, and clearly violating noise ordinances. All at the press of a button controlled by me on the fly.
Boricuoso787
Active Duty U.S. Navy
San Diego
2021 Challenger Hellcat Redeye Widebody
So the harness commands the plugs to full open all the time? Or they are commanded full open, then the plugs lock them that way bc no power after harness disconnect?
The Z Automotive plugs prevent them from cycling closed when, for example, you start the car in “Auto” mode. As you know, Sport and Track mode command the valves to full open, but that is after you start the car and select either mode (sanz Tazer). So essentially the car shuts off with the exhaust valves in the open position, then installing these jumper plugs prevents the valves from cycling closed at start once installed. There are ways to start the vehicle in Sport, Track or Custom mode (Tazer) which would command the exhaust valves to remain open at start. This is just the way I opted to go. They work great. Down side? I’d imagine that there is a possibility that the valves staying stuck open by way of these plugs “could potentially” lead to them ceasing in the open position after a long period of time. Though I’ve not heard of it ever being an issue, I’ll cross that bridge when I get there. For now, I enjoy that cold start sound every time I crank it and with my mid-muffler deletes, I enjoy not having to switch modes to get that aggressive roar when I step on the gas pedal.
That would be nice. For what they cost, should have a bluetooth function so I could control the valves with a phone app...now there is an idea.
yep, that wold probably triple the price... :(
I wasn't aware of that. That means that Im always driving around with them open, as I always use sport or track mode when i drive. Saved me some $, thanks
