All about the suspension
Thread Starter #41
catdad
Lake City
2019 Charger Hellcat
I see that Jon has tuned your car. Were you at Orlando MSHS?
Yes Car was running good but was dropping to 40psi on fuel pressure. I have that fixed now with a dual pump should come to life.
I was a spectator at Orlando.
I put twin pumps in mine as a safety factor.
I am always a spect tator at that place. Don't slow down or get runned ovah by an Asian in a rental.
Beautiful!! Didn’t have to tub it?
No. The car from a chassis and drivetrain standpoint (excepting the engine) is a legal DragPak. The cage is certed to 7.5 seconds.
Thread Starter #46
So, where can you find the strange drag pack setup on their site?
MPR in Almont, MI. Mike Pustenly (MPR) was a part of the original DragPak design group and he sells the 2015 version as a complete ready to install package. It’s all Strange engineering stuff. Including the fabricated housing with brackets, aluminum bolt thru carrier with Pro gears and spool or Wavetrac. 40 spline gun drilled axles, brakes with billet calipers, Strange adjustable shocks and Hypercoil springs. Also includes the crossmember that becomes a required part of the roll cage and ties everything together. Wheelie bars and the matching front suspension and brakes are also available. You would have to call and get a current parts list with prices as I’m sure it’s all gone up since I did it. I have a total of about $10k in the parts package for mine. That includes the front suspension (coil overs) and brakes plus the manual brake and steering conversions. B61CBA4F-EF4A-41A2-A57F-A0EB42D61DDC.jpeg 8D4FAC54-1766-4B8B-A060-9AEBC09F9B7A.jpeg F47613AA-19B4-4C0A-9C8D-F03AAD3657FE.jpeg FC2CDE28-137C-4ED8-A52C-6214B343B29C.jpeg 8C866AC4-1D4A-4C53-BBB1-774A32190849.jpeg 16719208-A01A-4099-A8D0-FB6F0B2DDA96.jpeg CE823F5D-BE3E-43CE-8166-1948F3F15CD0.jpeg
Thread Starter #48
MPR in Almont, MI. Mike Pustenly (MPR) was a part of the original DragPak design group and he sells the 2015 version as a complete ready to install package. It’s all Strange engineering stuff. Including the fabricated housing with brackets, aluminum bolt thru carrier with Pro gears and spool or Wavetrac. 40 spline gun drilled axles, brakes with billet calipers, Strange adjustable shocks and Hypercoil springs. Also includes the crossmember that becomes a required part of the roll cage and ties everything together. Wheelie bars and the matching front suspension and brakes are also available. You would have to call and get a current parts list with prices as I’m sure it’s all gone up since I did it. I have a total of about $10k in the parts package for mine. That includes the front suspension (coil overs) and brakes plus the manual brake and steering conversions. View attachment 104705 View attachment 104706 View attachment 104707 View attachment 104708 View attachment 104709 View attachment 104710 View attachment 104711
Absolutely beautiful
Thread Starter #49
that’s actually less than what I was expecting, wow
Thread Starter #50
My be a bit extreme for me right now. I’m Eager to see how @Hatermkr makes out with his new setup
#51
My be a bit extreme for me right now. I’m Easter to see how @Hatermkr makes out with his new setup
From talking to the shock company. And seeing they do a ton with no prep and small tire stuff plus circle track got me to buy them.
Thread Starter #52
I’m also looking for best bang for the buck to be honest. Not trying to throw the kitchen sink at it just yet
It is extreme from the install end of it. It requires a full cage that incorporates that crossmember and bars that tie in the 4-link link mounting points. Plus modifying the driveshaft tunnel and undercarriage over the rear end and replacing the fuel tank with a cell. Whole new fuel system and on and on. Once in, it’s fine for the street from a normal driving standpoint. The only thing that sucks is the manual steering. It’s still a heavy car and that Flaming River steering is like wrestling a bear. I would never suggest this is for anything other than the goal of a seven second car. For anybody wanting this….. you need to be able to do much of it yourself or have some connections and work some deals because if you have to pay the going $150 per hour rate… you might as well buy a DragPak. Picture of the other side of that….. 2BA21F55-80F9-4291-ADD1-DF179D882EDC.jpeg
Ever thang dun butt da driver. Kinda impotant. Just build the car around da cage. Youz bee okayed. Kinda may bee.
Thread Starter #55
I’m convinced I can’t do anything different driver wise due my times being so consistent every single run no matter what I do differently
Thread Starter #56
It is extreme from the install end of it. It requires a full cage that incorporates that crossmember and bars that tie in the 4-link link mounting points. Plus modifying the driveshaft tunnel and undercarriage over the rear end and replacing the fuel tank with a cell. Whole new fuel system and on and on. Once in, it’s fine for the street from a normal driving standpoint. The only thing that sucks is the manual steering. It’s still a heavy car and that Flaming River steering is like wrestling a bear. I would never suggest this is for anything other than the goal of a seven second car. For anybody wanting this….. you need to be able to do much of it yourself or have some connections and work some deals because if you have to pay the going $150 per hour rate… you might as well buy a DragPak. Picture of the other side of that….. View attachment 104740
Beautiful car. I’d probably that to an sxt and drive it on the street with a gear vendor
#57
Was thinking the same thing
Haha. Me too.
#59
I think the 3.70 is your biggest issue. I'd chage that to a 2.62 or 3.09.
I'd get the AAD drag pack arms and set to +.25 camber with you in it like HPIndy suggests.
I run a 2.62 and 305/45 17 MT ETR and have cut a 1.42 60' and my tune is way conservative. That was also on my old setup 2.4 blower and 2.72 pulley.
Thread Starter #60
Agreed, the 3.70 is just a relic from my trans swap, and honestly it sounds like it has major lash adjustment issues. I run 315s, so think the 3.09 is the way to go. Having a hard time justifying the $1500 for the AAD arms when you can get zero camber Redeye knuckles with new hubs for $600
