Damn F-150 Supercharged 770HP smokes the TRX…..😱.
I can’t believe this video is true and even question the TRX driver…..but damn if true.
Slipaway16
Bartle Skeet
2020 Trackhawk
More HP and should be lighter. I didn't watch the video, but the TRX is really no faster than a Scat Pack.
Yeh but but but but it’s huge I mean not even close
Slipaway16
Bartle Skeet
2020 Trackhawk
I'd say the TRX is over 1k lbs heavier and missing about 70hp with 35's weighing in at 105 lbs per wheel/tire. I'm not lying when I say a Scat or 5.0 will top end these things.
I'm about to move on from mine. I miss my old cat. Looking GT500 or Redeye. Whichever I can find a deal on first.
Not to mention the TRX is basically a off road truck & too tall.
How much for each? Real world. And put them up against the trackhawk / Durango hellcat
Slipaway16
Bartle Skeet
2020 Trackhawk
My wife's Hawk smokes my TRX. The Hawk does 0-60 in 3.4 on all season run flats and runs 11's stock. They lose some pull around 80 mph, but they can beat almost anything on the street up until then.
This is my favorite trackhawk....
Slipaway16
Bartle Skeet
2020 Trackhawk
SRTninja has a filthy one
Watched a TRX go 10.7 at cecil, driver mod recommended.
Slipaway16
Bartle Skeet
2020 Trackhawk
far from stock lol
"This Ram TRX features the factory IHI supercharger, but the blower snout has been ported by Kong Performance and fitted with one of their in-house 108-millimeter throttle bodies. Next, a 2.65 Griptech upper pulley and a 10% lower pulley were added, leading to more boost, while a set of FIC 1200 fuel injectors feed this beast with help from a methanol injection system. Finally, the truck features a custom cold air intake system and a 180-degree thermostat. All of the work was done by Labworx and it was tuned for E85 by Meesh_Tuned."
far from stock lol
damn, we heard it was only tuned for 93 that thing is wildly modified
Slipaway16
Bartle Skeet
2020 Trackhawk
No sir. TRX's run 12's stock. It takes some serious power to get 7k lbs into the 10's on 35's
WhipCat
In the Jungle
The results were expected based on the numbers.
the wheel tire combo alone makes a big difference on the trucks. That f150 is making 775 to the rear wheels?
The TRX makes about 605 to the tire.
On the dig the TRX take off so well, and then top end it drops off, which is exactly what I see on my truck.
you have a big weight disadvantage considering the aluminum f150.
seems correct. But it also shows what you have to do to beat a TRX in another pick up truck. You won’t run into this very often.
although that’s why I already pulley tuned my TRX. 2.85 with a pump gas tune. :):)
meanwhile across the border (Roush version) ...
@5:40
There's a dozen cameras mounted between the two trucks, but I better get more footage on my cell phone while I'm driving...
:ROFLMAO:
Slipaway16
Bartle Skeet
2020 Trackhawk
The TRX in the Roush vs TRX video isn't stock. He has an incognito lower.
That Ozzy t-shirt is worth at least 25 HP all by itself.
lol, years ago, I am talking like late 80s, I was flying commercial took a liking to Ozzy t-shirts, twead jacket, pressed blue jeans and black cowboy boots. (told you it was the 80s) Some folks were actually quite impressed. My favorite was the shirt for the Diary of a Madman. Had hair then (but not down to the middle of my back, that was later). Had to leave that shirt somewhere to be washed at one point, so drove my hotrod Z a couple of places i needed to go without the shirt. No one said a word (except some girls on the side walk). Was cut and well defined at the time so I guess they just thought it was cool. The chest hair helped with the icey winter weather.
Still would take a Peitz Trackhawk over either truck, if I had the money.
My buddies (Josh) Track hawk called "Gap Hawk" , Peitz tuned was running 10.20's at MSHS, upper & lower pulley on E85, in 2000 DA. Perty fast for as heavy as it is.
Cost of F150 with coyote. Id say 50k nicely equipped like a Ram 1500
Whipple, Headers, tune, exhuast is probably 15k a high of 20k
Lay off the options buffet of the TRX and some of these dealers discounting 22s. Id say they are probably close in price give or take a few grand.
