E85 in the morning is this tune related?
that's normal e85
Normal.
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
What about 30 minutes later?
If the smoke is blue'ish then it is oil. What is the temperature near you?
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
It is white. High 40s this morning. I live at 3800 feet in the very northern part of Tucson at the base of the Catalina mountains. Will snow once in a while. Oil is keeping level. Maybe not going to closed loop?
Mine does it in Fl weather it’s fine, usually spits out water from passenger pipe more than the driver
Remember, e85 attracts moisture. Don’t let the car sit for extended periods of time, when you start it up let coolant and oil get fully up to temp, and change oil at 3k miles or less
mine spits out water a foot or 2 and smokes a little from tailpipes until it’s all evaporated
Are you driving it for 30 minutes or idling?
You still have cats on it right?
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
High flow cats. I would not mind if the demon 170 had a 3 inch exhaust and bought two three inch cats. What is the strongest 3 inch cat on the market?
why cats? E85 smells good. 93 and no cats is horrible
My thought is the 170 has the same 2.75" exhaust as all the Hellcats do
I think GESI is the cat people use these days.
