Finally put my ingocnito sleeve on
rookerrobert
rookerrobert
Ridgeland
SC
2016 hellcat A8 and 2016 M6
Thread Starter #21
Absolutely not. Unless you are specifically tuned for it.
I'm not talking about a large amount of e-85 maybe 2 or 3 gal. per tank which would be maybe e-20
I would do 2.5 > 3 oz. of Boostane per 1/2 tank of 93. And at least have it checked by a tuner on a dyno to make sure it's dialed in & ok.
Don't worry about the Meth stuff.
Get a case of octane booster for the trunk and run 17lbs all day.
2fast4u
Edwardsburg
I believe e20 is the top edge of what computer can adjust for, it might throw a CEL....so, I would also say make sure tune is on target.
The dash wideband in the car is actually set to the stoich for E-15 fuel. You would be 100% safe until that point on the stock tune.
Here's what I do know though...at around 15% inferred ethanol content my flex tune starts blending tables to compensate.. so I wouldn't push it MUCH further than that point without at least the ability to data log what is happening.
Also...this website...for calculating content...is amazing IMO.
Ethanol Calculator - Brew City Boost https://www.brewcityboost.com/about/ethanol-calculator/
rookerrobert
rookerrobert
Ridgeland
SC
Thread Starter #27
Thanks for the info. and yes sir I have that same calculator....thats where I go my % from
Watch the octane boosters, @16GoManGoHC2 showed what his heads looks like after running it while and they were caked pretty good with orange deposits. He has pictures posted in his build thread.
I wouldn't try to mix e85 in as you'll have to keep very detailed notes over time. Would be a hassle I think.
A flex fuel tune while pricey may be the best bet.
rookerrobert
rookerrobert
Ridgeland
SC
Thread Starter #29
yep I think gonna do what you guys suggested from the start and just use boostane pro. I'm not looking to have quickest car in the county...just like have always said you be fast and it wont matter anyway in time you will get outrun.
swatdocsc
Law Enforcement
Jefferson City
MO
I use boostane professional and have zero issues. the orange coating has no bearing on plug performance. I have run this for years. every once and a while i'll run ms 109 when doing the track/HO button stuff.
You need to go have a look at @16GoManGoHC2 valve pics after running that stuff.
I run 93 with 17lbs but the tune for 93 has a lot of timing removed. Limited to 10-12* of timing max. The reason is you find the limit of 93 real fast, your knock sensors will tell you.
For track days with full timing enabled, 104. Is recommended to blend with 93 in 1:1 ratio. I have plenty of logs with knock and 93 gasoline, part of the trial and error when getting my car dialed in with my tuner.
swatdocsc
Law Enforcement
Jefferson City
MO
I had my heads off 2 months ago just a tinge of orange
That's good news. Post pics if you can with the ratio of product used so folks can compare. Maybe it's a case of "a dab will do ya" LOL.
swatdocsc
Law Enforcement
Jefferson City
MO
They were not even worth taking photos of, honestly nothing remarkable. I use a 1/4 can of the professional per tank of 93. keeps the knock boogie man away. and every couple of months I run a tank of straight 93 with a can of seafoam through for shits and giggles.
I have one for sale. We went a different route. Had it on my 2018 Charger for about 2-3K miles.
Not sure if this is allowed here?
Sent from my motorola one 5G UW using Tapatalk
So you use about 8ozs. to a full tank ?... I use 2 > 3ozs. each time I fill back up after going to track, I just fill up to 3/4 tank. I adjust up to 97 or 98 octane from 93. On data logs it never shows knock.
The 594 belt worked and dont have any belt slip but maybe I need one a little shorter?But anyway it runs great and gave me 2lbs. more boost so now I have 2.85 upper and sleeve running 17lbs. Any thoughts?
Tuning changes?
I’ve run one of these 4oz bottles when I fill up from a 1/4 tank. Boostane calculator states this changes my 91 octane to 93 octane. I’ve been doing this on my 2015 since 2016 with no issues.
swatdocsc
Law Enforcement
Jefferson City
MO
Well gents pull up an ammo can and pop a squat, the way this product came about the owner Ethan who told me this personally who is a chem engineer by trade, would go out with his Dad on those big racing boats. and those require serious octane fuel requirements and fuel stabilization, so he developed his product to suit that need I believe he had some connection with torco years ago (I forgot exactly how that was in our conversation) but not only does the boostane boost octane its a semi fuel stabilizer. I have used it my self and had zero issues. and for the record anything that burns is going to leave some residue, your comparing it with running ethanol which has a hydrotropic property to it like a detergent. gunpowder residue gasoline residue but there will always be some. now speedy pass me a beer.
