SHOW ME THE DIFFERENTIAL CARNAGE !
Trader history for Hemituner (0)
stonewall
Conway
AR
2017 Dodge Hellcat Challenger
I mostly drive my car on the street and have had no issues from excessive heat build up over the norm. A few things to keep in mind, none of the old school diffs or other aftermarket diffs available for our cars have cooling fins either, aluminum dissipates heat faster, we are now using synthetic gear oils compared to old school which are much better, plus you would create higher temps on the track then you would on the street. I am also changing the oil in the diff more often. If I do notice any issues along the way, then I can always install a diff cooler. But so far everything looks good.
True. it sure is a beautiful piece. I didn't know anyone was building one.
stonewall
Conway
AR
Does it run Dodge internals? clutch packs/gears?
DemonSRT
Kawartha Lakes
It has all of the internals used in the Demon's/Redeye's with a modified/improved clutch pack.
DemonSRT
Kawartha Lakes
AJ is using this in his Charger which did get into the high 7's with no issues. He tests all of his products personally to make sure that it works and is reliable and if there is any problem at all he always stands behind it and goes out of his way to rectify it.
