Two Piece Rotor Hardware Failure.
So, I had what I thought was the dreaded front rotor click... but this was more substantial. I pulled the wheel and found that the H-Bobbin spring clip had broken and was interfering with the outside rotor.
All in all, I had 5 spring failures.
I sourced some clips and set to replacing all 20 of them.
Here is my How-To thread:
https://www.hellcatforum.org/threads/how-to-rebuild-front-two-piece-rotors.8968/
If you are experiencing a substantial click, under heavy braking, take a look at the spring clips. You don't need to pull the wheel, to see the failure.
I only heard it, under heavy braking. In time, I'm sure it would have been a more dra.atic failure.
NOTE: These are Centric 126.63088 rotors, but of the same exact design, as the Brembos. Just trying to help identify a weak point, on any of these 2 piece rotors.
Hope this helps.
Bob
Bboyd
Monongahla
2017 Hellcat
Good looking out!! I will definitely check mine!!
I carry extra pieces with me for the DP rotors in my track day be ready for anything kit.
Will check mine today, only get it under extreme braking like at the track. Good call!
2011 chrysler 300
Do you happen to have a link to them? I am going crazy trying to look for them.
Seems like this was supposed to go to the Wiki...
:unsure:
T_Trahan44
Spokane Valley
2012 Challenger SXT
That’s terrifying. Definitely a stressful thing to find. I can only hope everyone went to check on theirs after seeing this! Especially those that Daily these cars.
