Sign Up! To view all forums and unlock additional cool features
Ask yourself why SRT engineers changed internals and put on a larger supercharger on a Demon/ Redeye engine for only 3 more lbs of boost? (Hellcat 11.6psi /Redeye 14.5 psi) Litens will make 1-2lbs of boost at sea level now go negative 1500DA with no tune. If something goes wrong who you going to blame?
Litens testing shows that this pulley makes approximately 45 HP on 93 and 65 HP on MS109 Race Gas for Demon/Redeye Superchargers at sea level. Litens testing shows no tuning is required with this pulley upgrade.
They also say you don't have to pin the crank with the 3.17 but in the fine print it says if something goes wrong it is not on them. Kit Includes:
1 - 3.17" Litens Supercharger Pulley
1 - End Cap (dust/tamper shield)
1 - 17mm Install Tool
1 - HD belt
Note 1: Pinning of the crankshaft pulley is not believed to be required with use of this pulley but no liability is assumed or implied by High Horse Performance, Inc. due to any damage that may occur due to unpinned cranks. Note 2: Litens highly recommends against the use of additional idlers or heavy duty tensionsers and HD belts with their pulley due to the higher risk of internal failure. Failure caused by running these other parts may not be covered under warranty.
Like I mused and thrushed be more. I will be pinced in to throw the 1st rock $$ wise to see if this rocks and romeos.. Very overies and uninterested to sea if it works or snots.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
