Sign Up! To view all forums and unlock additional cool features
After watching the GT500 videos I have a question about the A8's in our cars. If you hold both paddle shifters back at the same time while the car is in drive will trans go into neutral?
I wouldn't even have mentioned this but when you pull both paddles back on the new GT500 that trans goes to neutral even with the gear selector in drive. I know they have a totally different trans but I thought that interesting.
I don’t think you can select neutral with the paddles, I know if you hold the right one back it will return to D drive . I only use it at the track it holds the gear a bit longer but I still let the car shift itself.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
