Sign Up! To view all forums and unlock additional cool features
I thought primarily top end more robust valve train gear and springs for added RPM and load going from HC to RE or Demon 6,500 vs 6,200 RPM for internals, then the obvious larger blower with power chiller for bolted on externals
In order for these to not be 50 state for all cars there has to be some other difference that would produce a change to or effect performance & emissions.
I find it hard to believe that a change in the head gasket to allow more oil flow would be the only physical difference.
Depending on head gasket thickness it could only change change compression height varying compression. Unless water gallery passages or oil drain back, am I missing something here
Here is some Eye Candy for anyone interested....notice the spark plugs are included as well...Guys this a a Mopar Direct Connection Performance Part. These can only be ordered thru a Power Broker Dealer and according to them they are hard to come by. This set is brand new and ready to ship.
NICE Stuff!!
All factory head gaskets now have the .118” diameter oil passage holes. The original .062” holes in the 15, 16, and 17 model years are obsolete and the only replacement gasket available unless you get gaskets from Cometic which are still .062 is the gaskets with the larger orfices. See the difference?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
