Need help
I need some help. I am about to order the Diablosport PCM and it's asking me for the calibration code. Yesterday, I accessed the factory one, but unlocking the top pin connector has proven to be quite a challenge due to the tigh fit of the PCM and in order to read the calibration code I need to pull it out. Any tips? Do I have to remove the cross member, or is there an easier way? I removed the push pins and took out the 13mm bolt that holds the PCM to the cross member, but can't get enough clearance to read the CC without actually removing that connector. Any help will be appreciated. Also what size is the nut with integrated washer that holds the PCM to the holding frame. I lost one.
